Battery drin issues ui7
(Topic created on: yesterday)
7860nurul
Ui7 ke bad Jo security update aaega
Usmein battery sold ho jaeg battery drink jyada ho raha hai pura din chalta hi nahin Hai battery
4 Comments
BiRdMaN
It is normal nowadays with the ONE UI 7 update
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will add/fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful I'd appreciate it if you could Accept it as a solution Thank you 😊
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
