S25 ultra ringtone volume is decreasing on its own
(Topic created on: 03-02-2025 05:44 PM)
getCSV
Beginner Level 3
Hi, I have a 1TB S 25 Ultra and it is very irritating to see that the ringtone volume goes down to zero in its own!! I dont have adapt sound on. Can Samsung or someone please let me know the fix??
4 Comments
Ultra_Devil
Check the ph cover.. I had face this, .. now it's fine..
goodthings
Please reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too also clear catche of all apps manually then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution . Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
