Samsung_ka_beda _gark
Beginner Level 3
02-28-2025 11:21 AM in
Most of time, it does not show recent history or last 24 hours history. Only shows a 2 to 4 messages history. Raised the issue on Members but still they are giving #wahi_ghisa_pita_jawab *we are working*.
3 Comments
cs_member10
02-28-2025 04:19 PM in
Galaxy SDear Samsung member,
We want to inform you that it is the normal concept of the notification history feature that it doesn't show 24 hours history.
We appreciate your feedback regarding this matter and will take it into consideration for future updates.
If you have any other questions or need further assistance, please feel free to reach out.
Beginner Level 3
4 weeks ago in
After latest update, the notification history problem still persists. It seems that samsung is unable to handle this problem. It may be normal concept for you but it's very important for someone. And if this is a normal concept for you, then why this problem is not being solved by you.
Lakshay31
03-03-2025 09:52 PM in
Even I don't like this type of notification history in one ui 7. earlier I was using s21 fe and it used to had a complete history of notifications.
