Resolved! Solved
S20 plus WhatsApp notification sound problem and WhatsApp noti panel history prb
(Topic created on: 12-13-2020 10:35 PM)
Mesbah3575
After Android 11 upgrade i format my phone...After that notification sound not coming....and notification are not showing on my notification panel....
Please say any solution..
Ehsank
bro try these steps and lets see
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
16 Comments
Ehsank
once clear cache of WhatsApp
and then check
Ehsank
or do one thing more
go to settings >general Management >reset>reset settings then check
Mesbah3575
hey buddy it's not solved yet
Mesbah3575
I don't know what to do now to bring back my notification history and sound
Ehsank
Steps to perform.
Mesbah3575
ok now I'm trying this
Mesbah3575
thanks buddy..reset app preferences helped me😊😁🤗
thank you so much...your advise means a lot
Ehsank
happy it helps you
and with thanks you can also accept as solution by CLICKING on 3DOT at my comments 😊🙂
Not applicable
it's not solved because already samsung removed bubble notification in Android one ui 3.0
