Top speaker not working for notification sounds on S21 FE
(Topic created on: 3 weeks ago)
byteBox
Hi, I’m using the Galaxy S21 FE. I noticed that the top speaker doesn’t work for notification sounds like WhatsApp messages, phone lock/unlock sounds, etc. Only the bottom speaker is working for these.
But when I play videos or when the phone rings, both top and bottom speakers work fine.
Is this normal or is there a fix for this? Please help.
2 Comments
SuperKing2005
Contact Samsung Support Or Visit To Your Nearest Samsung Authorised Service Center And Get It Checked.
cs_member10
Dear Samsung Member,
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
