S25 ultra fast charging connect and disconnected automatically any solutions
(Topic created on: 02-27-2025 11:34 AM)
Hiteshc00l
Is this a device fault or some update might fix this ???
14 Comments
Hiteshc00l
Software issues or device faulty?
nk023
Looks like software issue, this issue also present in my Tab S9.
Hiteshc00l
Dint expect this from samsung atleast not from latest model
Kunapatra
This is software issue and it will fix in next Security Patch and it happen sometimes because the ONEUI is new phone also so wait for sometime
cs_member10
Dear Samsung Member,
1.Kindly check the power socket functionality with a different device or try to charge the device in a different power socket.
2.Please check whether the charger cable and adapter are fixed well. Remove the charging cable and reconnect with the mobile phone properly.
3.Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
4.Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
5.If the issue is still not been resolved, Reset the device:
IMPORTANT:
•Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
•Remember google password before resetting the device because it is required during initial setup.
•If you do not remember it, then reset, (Forgot password) your google account.
•For this:
•Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
