02-08-2026 05:17 PM in
Galaxy S- Tags:
- @samsung
02-08-2026 07:36 PM in
Galaxy S- Mark as New
02-08-2026 07:47 PM in
02-09-2026 11:25 AM in
Galaxy SDear Samsung Member,
● Kindly check physical condition of your camera lens.
● Kindly clean the camera lens by microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
02-09-2026 11:30 AM in
02-20-2026 12:08 AM in
