S24 ultra sound output quality is very poor compared to iphone
(Topic created on: 10-27-2024 07:15 PM)
jenz219
Especially while using ear buds even if dolby is turned on...anyone facing same issue
5 Comments
MukhtarK
Try to Reset your device
jenz219
It is not specific to my device i guess...samsung generally has poor audio output quality...when i use same buds in my iphone the instrument seperation and quality is far more superior
Luvkuchh
I am using the Buds 3 Pro, and they sound fantastic.with my s24 ultra
cs_member10
Dear Samsung Member,
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
anky11
I also own s24 ultra and since last 1-2 weeks I feel that sound output to galaxy buds and my car has drastically dropped. Tested connecting car system with an iPhone and it worked much better
