S24 ultra fingerprint sensor issue
(Topic created on: a month ago)
Karthick_________
I'm experiencing an issue with my Galaxy S24 Ultra. When I put the phone in my pocket with the screen off, the fingerprint sensor seems to activate repeatedly due to contact with my pants. This is causing unnecessary battery drain. Has anyone else encountered this problem, and are there any solutions?
cs_member10
Dear Samsung Member,
As per your inquiry, we would like to inform you that it is a normal behaviour of devices that, when the screen comes into contact with clothes or skin and accidental touch protection is enabled on the device, this may lead to certain actions happening automatically. Similarly, if the fingerprint sensor comes into contact with anything unauthorized, it may temporarily fail to recognize the authorized touch but will resume normal functionality after a few minutes.
Please perform the below-mentioned troubleshooting steps, these may help in resolving your device battery drain concern.
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
