S24 ultra display issue
(Topic created on: 02-06-2024 10:16 PM)
ynayak
I am sharing some photos of the s24 ultra i have in comparison with the s24 ultra present at store. The screen colors are not the same . I have placed a return request but i dont know what test they do at service center, their results are "Ok" for the phone. And the service center person is ignoring the issue literally by saying "its AI display".
In this one the wallpaper set was same and the blue/violet is appearing gray on my device
Sivadgokul
Bro don't compare your mobile with the mobile present at store..store mobiles are kept at store mode which will be brighter and vibrant..your mobile display quality is good only..don't get confused and mustaken
shivmgor
100%
Amol102
Compare s22 ultra..s22 ultra display is really good
This is not an issue, i hope. it should be a setting change.
Bcz i find my display is good and better compared to others
ynayak
All the settings are same. And that is what i am saying that my device has got some issues.. the icon, content everything i can notice as i was using s21 earlier
May be, but check after the 1st update, so if there is an issue, may expect that to be fixed
Pratik31
There is difference in size of both phones.. how is it possible??
Something fishy... in which showroom did you compared ?
I was thinking that only and how come no one has pointed it out yet.
JohnAshu
There seems to be difference in size of noth devices
