S24 ultra display flicker issues
(Topic created on: 08-30-2025 09:59 PM)
BMY_space
It has been a few months since I had the display on my S24 Ultra replaced. Recently, it has begun to flicker, even though I have been using it normally, such as scrolling through my gallery.
I brought this issue to the attention of a nearby authorized Samsung service center, and they have recommended that I replace the display once more.
Any suggestions...!
3 Comments
goodthings
Kindly complaint to Samsung customer care support through Samsung Members App as error report also send log files along with this error report for this issue and go to service center for check and resolves this issue. If you like please accept it as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
1. Go to Settings>Display>Adjust the brightness.
2. You can reset your device by following the steps from the below link.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
