S24 plus Fast Battery Draining
(Topic created on: 07-18-2025 02:09 AM)
Angshuman4
My samsung s24 plus's battery is draining fast. I tried all the possibilities to fix the battery backup like factory reset, limiting some apps, dark mode on, light performance profile, disabling some settings etc. but there is zero improvement. This is due to the faulty and less optimized software (ONE UI 7). Currently my phone got the new july security patch. Even in this update, there is no improvement of battery backup. Please fix this issue.
15 Comments
goodthings
Angshuman4
Done
goodthings
You're welcome.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request you to share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Sachin_92
This is problem with samsung phones so that i dont update from july 2024 my battery backup is very good.
