S24 plus: 25W vs 45W. Which cable to use for fast charge 2.0?
(Topic created on: 03-23-2025 12:01 AM)
Kfl2050
  1. For the Galaxy S24 Plus, which charger adapter is recommended: 25W or 45W?
  2. To achieve Super Fast Charging 2.0, is the cable included in the box sufficient, or is it necessary to buy a separate 5A cable when purchasing the 45W adapter? Some claim the 3A cable provided with the phone is enough, while others say it won’t support Super Fast Charging 2.0.
  3. What is the difference in charging time between the 25W and 45W adapters when using the cable that comes with the phone?
Thanks in advance!!
3 Comments
SReddyG
1. You better go with 25W, because it heats up the mobile less.
2. To achieve super fast charging 2.0 till S24 series, you need a 5A cable. This year in S25 series they changed the charging technology it seems. So it's getting super fast charging 2.0 with the cable provided in mobile box itself.
3. You won't see much diff if you check till 100% side by side. It'll be hardly 7 to 10mins fast. But till 90% 45W will show some 15 to 20min diff when compared to 25W
sayeedAshrafi
Only 10 mints difference gor fully charged
AudioJack35
Get 45w Original Samsung charger from Amazon its about 2.4k
Buy eco friendly logo charger (it's GaN and is smaller new 2024 model)
For charging cable keep the in box cable or buy Apple type c cable 5A for reliability
