S22 ULTRA Fast Charging issues
(Topic created on: 05-31-2025 10:58 PM)
DinoSebastian
I've been experiencing a serious fast charging issue ever since updating to Android 15. After the update my phone no longer charges in fast mode and it's extremely frustrating. I've already tried switching cables and adapters of samsung itself to check if this is caused due to any issues with my cable and adapter and even tested various power sockets—none of these made any difference..Everything else seems to be working fine, so it's clear this issue began after the update. Previously, my phone would charge from 41% to 80% in about 25 minutes. Now, it takes nearly an hour to reach the same level, which is a significant downgrade... This latest update has really messed things up.
10 Comments
DinoSebastian
Does it anytime shows superfast charge earlier or only fast charging ?
DinoSebastian
Used to show super fast charging! It shows even now while plugging the cable for like 5 sec and goes back slowly charging
I guess then you have tried for factory reset as well.
If not try once. Cz in my case my super fast charging is improved a lot after oneui7. It may be a issue you can try wipe cache or factory reset after data backup.
DinoSebastian
I tried cache clearing but no hope!
I doubt if the issue will solve after factory reset
Everything was good, once i updated the issue started
cs_member8
Dear Samsung Member,
● We always recommend to use genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Check charging: If rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Kindly check if ''Multiple applications'' are running in the background of the device. When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
DinoSebastian
Have done all this troubleshooting steps!
This is to do with the latest update and nothing else
Just get this sorted ASAP
DinoSebastian
I need a solution for this
This is terrible.
NagendraMorla
Beginner Level 4
I am facing the same issue fast charging is not working i have tried different scokets and cables no use its showing only charging
