01-30-2026 07:52 AM in
Galaxy S- Mark as New
01-30-2026 04:17 PM in
Galaxy SDear Samsung Member,
1. Galaxy device Performance issue: ● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
2. Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
