S24 fe battery issue
(Topic created on: 08-29-2025 02:40 AM)
Rudra_nryn
I just bought an S24 FE handset and I am facing an issue. The battery status says it's charging when plugged in with a wired charger, but it just doesn't charge at all. I had a hard reset of the phone, but the same thing happened. What should I do?
8 Comments
Original charger, cable chahiye.
Rudra_nryn
I have it original
I have tried other brands it given a warning sign. So I guess.
Rudra_nryn
Turns out it was a charger issue nevermind🤧
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request you to share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve the issues.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Cutegril90
Expert Level 4
Congratulations 🎊 👏 😂😂Ye to tatti hai 💩💩💩💩💩💩💩💩💩💩💩💩💩💩💩💩
