S24 Ultra after Using under water
(Topic created on: 08-31-2024 09:26 PM)
Sebbie_131
I used my S24Ultra today to celebrate my Birthday in Atlantis Water Park. And I used it underwater to take photos and video's., after a while I felt like it's getting hot during the weather outside, after a few minutes I noticed that the photo quality is getting worst. When I tried to clean the lens I saw the that there's moist inside the 4 camera. I was very upset.. 🥹🥹
14 Comments
Qusaimoh
From the pictures, it looks like you might have a lens protective cover on your phone. Is that correct?
It seems like the moisture might be trapped under the protective cover.
Sebbie_131
It doesn't have protective lens cover at all..
ojwh
How come you decided to use your phone underwater for sustained periods?
I suggest you research other devices meant for that sort of purpose, like the GoPro, for diving & snorkeling.
https://gopro.com/en/us/shop/activity/dive-snorkel?srsltid=AfmBOorTrpldOCvqBsF94-n2N7fZgGtY98oWhAVO3...
Sebbie_131
I should've think about this..
Ali_Elwasief
Maybe it is because of Dubai's temperature or because you used it longer or deeper than what it's rated at.
Sebbie_131
It's was with me all day inside the plastic pouch.
Ali_Elwasief
No! These plastic pouches still allow water to get in, and in temps like this, it could make it worse as it is plastic.
Sebbie_131
I dont know... Lesson learned..
Sebbie_131
I brought my phone to the nearest samsung store (dubai mall) the guy told me that the phone should not be soaked in pool with a high temperature with chlorine.. because it can damage the the it's self. We can only use it with the normal water like in rain or bath tub. (Lesson learned)
