S24 Ultra – Call Vibration Stops Randomly Until Reboot
(Topic created on: 05-18-2025 11:17 AM)
GK0700
Beginner Level 4
Hi everyone,
I’ve been facing a strange issue with my Galaxy S24 Ultra. Randomly, the phone stops vibrating for incoming calls—even though the settings are all correct (vibration is on, intensity is full, DND is off, no special Modes active). The only way to fix it is to restart the phone, after which it works fine for some time.
This has happened multiple times now and seems like a software glitch. I'm on the latest software version.
Anyone else facing this issue? Any workaround other than rebooting? Would appreciate if the Samsung dev team could look into this as it affects basic phone functionality.
Thanks in advance!
6 Comments
Is this issue present in one Ui 7. Almost all user are facing all kind of issues in one Ui 7.
GK0700
Beginner Level 4
Yes i am uaing one ui7 but i recently updated, this issue was present in one ui 6.1 too before i updated.
Only solution is to wait security update or one ui 8 or ask Samsung support to solve your issue .
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given link.
● Galaxy device vibration issue: https://www.samsung.com/in/support/mobile-devices/solutions-for-when-your-galaxy-phone-wont-vibrate-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
