Thursday (Last edited Thursday ) in
Galaxy S- « Previous
- 1
- 2
- Next »
Friday in
Galaxy S- Mark as New
Friday in
Friday in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
Friday in
Friday in
Friday in
- « Previous
- 1
- 2
- Next »
