S24 Ultra Battery Drain Issue
(Topic created on: Thursday)
sumukh_ck
The S24 ultra is facing severe battery drain issue post One UI 7 upgrade. Even after may update its the same. Why is the company not solving customer problems on priority??
Its better we move to some other brand if this kimd of support is given.
4 Comments
Maverick77
Dial *#9900# and then go to reset battery logs
After that restart
sumukh_ck
I tried. Dint help :(
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
sumukh_ck
Thanks. But you are literally telling everything possible to do for a premium phone. Why should we buy it if we want to put all these. I can buy a 20k phone and use for 2 days. There are several users reporting this issue, why can't the company take it on priority and fix it.
So please consider this on priority.
