S24 Network Problem
(Topic created on: 02-23-2024 12:23 AM)
DIPESH072
I purchased s24 today from offline store. I am facing following problem
1. Network problem
2. No 5G Only option
3. No internet connection even on 4g lte+ , internet working fine on other devices in same Location.
Kindly resolve network related issue as soon as possible. Thanks .
6 Comments
Mayur000
Just go to that offline store and ask them regarding problem.
Or return back.
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time, restart your's device without any Sim in slots also interchange Sim in slots,turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Congratulations for your AI S24. Thanks.
DIPESH072
I purchased s24 not s24 ultra .
goodthings
No matter. Thanks.
cs_member10
Dear Samsung member,
As per your query, we have noted down the feedback related to this feature (5G Only option). We are continuously working for making our products better and more efficient.
kindly follow the easy troubleshooting steps which might help to solve the issue.
Check device network in open area
Check device network mode settings
Please follow the steps: Navigate to apps screen and tap on Settings>> Tap on Connections>> Tap on Mobile networks>> Tap on network mode SIM1 or SIM2>> Select network mode
Note: We recommend to set device network mode as 5G/LTE/3G/2G (auto connect) mode.
Check network operator settings
Kindly set device network operator as "Automatically".
Please follow the steps: Navigate to apps screen and tap on Settings>> Tap on Connections>> Tap on Mobile networks>> Tap on Network operators>> Select automatically>>
Note: We recommend to set device network operators as automatically.
Tap on OK>>Registered on network.
Check SIM cards
Kindly do check same SIM card in another phone or another SIM card in same phone to verify the issue.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
