S23ultra battery issue
(Topic created on: 10-05-2023 10:54 PM)
mazhathulli
My S23ultra had only getting SOT 3 Hour why like this what is the issue
7 Comments
abbas00
Keep always battery saver on
MOQBALI
If your Samsung Galaxy S23 Ultra is only getting around 3 hours of Screen-On Time (SOT), it's significantly lower than expected for a flagship phone. There are several potential reasons for this:
1. **Battery Health:** Over time, batteries degrade, and their capacity diminishes. If your phone is old or has been heavily used, the battery might not hold a charge as well as it used to.
2. **Battery-Intensive Apps:** Some apps, especially those running in the background, can drain the battery quickly. Check for any apps that might be using a lot of battery in your phone's battery settings.
3. **High Screen Brightness:** Keeping the screen brightness at maximum consumes a lot of power. Try reducing the brightness or enabling auto-brightness.
4. **Background Processes:** Background processes or syncing activities can consume power. Check if there are any apps that are continuously running or syncing unnecessarily.
5. **Poor Network Signal:** Weak cellular signals can cause the phone to work harder to maintain a connection, which can lead to increased battery drain.
6. **Location Services:** Constant use of GPS and location services can be a significant battery drain. Make sure these are only enabled when necessary.
7. **Software Issues:** Occasionally, software bugs or glitches can lead to excessive battery drain. Ensure your phone's software is up to date and consider checking for any rogue apps.
8. **Battery Optimization Settings:** Make sure that your battery optimization settings are configured properly. Some aggressive battery optimization settings can hinder the performance of certain apps.
9. **Hardware Issues:** While this is less common, there could potentially be a hardware issue with the battery itself.
If you've tried adjusting these settings and the battery life still doesn't improve, it might be a good idea to contact Samsung support or visit a service center to have the battery and phone checked for any potential hardware issues. They'll be able to run diagnostics and provide more specific guidance based on the condition of your device.
MOQBALI
Hello
*#0228# You can try this code to reactivate the battery
If the problem is not resolved, it means that the battery needs to be changed, or you have some applications that need to be put in sleep mode
mazhathulli
The code is not working
MOQBALI
Try this code *#9900#
Then go to battarystatsrest
mazhathulli
Done
MOQBALI
If you understand the options in this code can help you to improve your mobile 🫡
