Midhunsureshbin du
04-29-2025 11:24 PM in
Guys, anyone facing the battery fast drain issuse after the UI 7 updates kindly share the same issue some found 🤔 🙁 🙏
Even i am always turning on Power saving mode time also 🤔 🙁 🙏
Samsung kindly resolve the issue 🤔 🙁 🙏
5 Comments
GalaxyNerd
04-29-2025 11:42 PM in
There you go 😂 everyone was desperate for oneui 7 and now everyone will regret updating it.
Bergin
04-30-2025 12:54 AM in
It will optimize after 1-2weeks
best00
04-30-2025 05:31 AM in
After releasing the new UI ,you should wait at least a week...bug must be there...
Hope Samsung will solve the issues ASAP.......
blu0wen
04-30-2025 11:04 AM (Last edited 04-30-2025 11:05 AM ) in
All series have the same issues after oneui7 installed, but i noticed after more than a week of using the battery adjusting by itself, depending how you used it.
Bassam_Mahmood
05-01-2025 01:46 AM in
I have the same issue with my S23 Ultra after installing the update and if you focused you will find that the charging speed become slower( when using wire charger with fast charging off), also the RAM usage has been increased (before the update the RAM usage was between 4.** GB to 5.** GB, now it's from 6.8 GB to 7.6 GB most of time)
Also the location service icon appears on the notifications area near the battery icon almost every 4 or 5 minutes and every time I use any app.
