Battery issue
(Topic created on: 05-13-2024 09:18 PM)
Surazmanee
I have notice that after upgrading my Samsung galaxy s23ultra from One UI6.0 to One UI6.1 there is bit drop in battery performance in terms of charging speed & battery life, even after using 45W charger the charging seed is less comparative to UI6.0 secondly, the battery life reduce to 50%. A 100% charge last only half a day where as it was lasting full day with 100% charge in earlier UI6.0. I tried all necessary settings battery performance but no difference at all. Is anybody facing the same.
6 Comments
B3RD
Yeah am also have the same problem but,
Try not to use the 5G all the time , for me I use it only when processing update. Or loading.
TraverS
After updating it needs a few days to calibrate battery according to your usage patterns.
Is fast charging enabled?
Surazmanee
Yes.
vijayakumara
My phone is running low on battery without using it. Can you help me figure out what to do?
Pruone
After every major updates i recommend you to do a complete factory reset. Factory reset will clear all the old cache and improve the device as well as battery performance. Please take backup before factory reset
Samsung_specialist
Certainly, here are the steps:
Be aware that 5G service may consume more battery.
Optimize your phone battery usage.
Optimize the overall usage of your phone for better efficiency.
Adjust background usage limits to conserve battery.
Close all applications running in the background.
Activate Power Saving mode to extend battery life.
Use the device in Safe Mode to troubleshoot any battery draining issues.
Ensure you're using a compatible charger and avoid using old chargers.
Check if the charger used is compatible with your Galaxy device.
If these steps do not resolve the issue, we recommend raising an error report from the Samsung Members app. You can find detailed instructions on how to do this by visiting the following link: https://www.samsung.com/ae/support/mobile-devices/raising-an-error-report-via-samsung-members-app/
