S23Ultra sensor shift issue?
(Topic created on: 02-10-2024 07:01 PM)
TSeries
Is this normal?
22 Comments
CHANU_99
2nd zoom didn't change the lens. That's not normal.. every phone has this issue! Close subject can't be taken with telephoto lens 😐
TSeries
In this video I only used 0.6x 1x 3x
0.6 to 1x shift is noticeable.
CHANU_99
Yes.. but when you turned to 3x, it didn't change.. pay attention here!
TSeries
It did change lens. Can tell by the color change.
CHANU_99
I don't sure! Colour changed a little for zoom, i.e cropping the picture
CHANU_99
Please try again with subject in distance.. & compare..
TSeries
OMG
You are right.
I tried covering 3x lens and took a video and it still zoomed 3x with primary camera.
And continued filming with 10x and camera frozed.
CHANU_99
Yeah! That's I'm telling.. telephoto lens doesn't works on close subject..😐 only for far subjects...🤦 You can't take a clearer close picture by tele lens.. you can't able to focus the subject, when you focus, it will come back with main sensor.
CHANU_99
Yeah! When you use 10x or more.. it will forcely does with tele lens.
