S23Ultra Charger with Super fast charging 2.0 with 45W vs 65W
(Topic created on: 10-07-2023 08:24 PM)
YashSonii
Both the charges performs very well.
The advantages of 65w charger it it comes with a long 5Amp C to C cable which allows mobile to charge device with Super fast charging 2.0 which is way faster then the 45w charger.
35%-100%
65W - 49min(Super Fast Charging 2.0)
45W - 1hr 3min(Suber Fast Charging without5amp cable)
25W - 54min (Super Fast Charging)
15W - 1hr 15min(Fast Charging)
below 15W - 1hr 32min (Charging)
13 Comments
RĀJ
Samsung 45 W charger also gives 2.0 speeds
YashSonii
For that u need 5amp caable that not included in box i think
Martii
Initially i have used the 45w charger with in box cable completed full charge at 50 min in Air conditioned place.
RĀJ
It is included
YashSonii
Idk abot it i will edit
Nav2396
It is included
Suresh0143
Samsung S23 ultra september update not supporting 45w charger....
YashSonii
Really???
Suresh0143
I'm using 45w charger...before september update its works super fast charging....charging time is max 1hr....
Now September update 45 w charger connect its showing super fast charging but time is 2hrs...it's horrible update...🤨😡😡
