S23 ultra performance and battery downgraded after OneUI 6.1 update
(Topic created on: 03-28-2024 11:13 PM)
MyInnerDemons
I did geekbench 6 after the update and got no performance upgrade were as it's single core performance reduce from 2280 to 2010 and battery backup is horrible after the update.
Please report this as much as possible to samsung.
Thank You
23 Comments
Widget of battery in lock screen only show s pen detail in round bar option.
MyInnerDemons
No it should show for the device battery as well.
Yes it is available, my mistake .we can change and there is choosing options also.for that just do double tab on it
S_Kumar73
Expected
Gundra
This custom one ui 6.1 is in test stage.. may be more updates will fix this bro.. as our processor is sd 8 gen2. They need to customize everything which runs well for this processor.. hope it will fix soon..
MyInnerDemons
Yes bro u r right but reporting this to samsung will make things better for both the sides.
Please do report this to samsung
S_Kumar73
MyInnerDemons
If this is your result of geekbench 6 then bro try again because this is very low or you phone performance is not right take it to the service centre.
S_Kumar73
Out of warranty, what they will do. Whats the actual result
