S23 ultra: big problem after update
(Topic created on: 11-13-2023 09:05 AM)
Shubham_sony
after updating my device to android 14.... i am unable to send sms from secure folder. i can't regoster my number in phonepe...google pay...imobile....axis mobile....Au banking etc. any application that verify you by mobile number can't work after update. it shows sending sms failed. please do some needful at the earliest.
23 Comments
Mehz
Mine is working perfectly fine.. go to service center they will help you with the connection problem
VinodSolanke
In secure folder ur phonepe n gpay is working
Shubham_sony
i have already gone there ....they reset it too....but facing the same issue...
Martii
Did you tried changing default messaging app??
Shubham_sony
i made a factory reset too
Shubham_sony
yes
Jithin1995
Hi all me also facing the same issue after once i updated to 14.
I tried to do a factory reset also but still the issue has remaining..
Any solution ???
Shubham_sony
i still searching solution.... i also reset my device twice and also visited nearest samsung care they again update my software but still i am facing same issue....contacted samsung care team but they said this feature will permanently stops in all android 14 devices. one device one app.... let's make a team and daily send them our issue then we will get a solution....not a single user can make change. post and repost this issue again and again and tag them they will look and made a solution for this problem.
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Without a log file, we cannot analyze this issue, This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
