07-23-2025 08:29 PM in
Galaxy S- Mark as New
07-23-2025 08:30 PM in
Galaxy SOpen Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful I'd appreciate it if you could Accept it as a solution Thank you 😊
07-24-2025 11:35 AM in
Galaxy SDear Samsung Member,
As you are facing multiple issues with your device, we kindly ask you to share the log file with us. Additionally, if you have any video clips or images that illustrate the problem, it would greatly enhance our understanding.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
