S23 ultra battery draining issue
(Topic created on: 10-26-2024 06:55 AM)
OrcaDee
Post Oct update to One UI 6.1 , I see so much of battery draining , I just bought new phone, it's been only 12 days, I regret That I updated the new patch, every user of S23 ultra is voicing the same battery Draining issue on this forum , but I still see samsung providing same old solutions for everyone instead of working on a software to optimise battery and find the fix.
@Samsung, @samsungindia please provide the justice for all s23 ultra users, We trust the brand and buy products, please don't make us to lose trust. Please provide the fix
11 Comments
Mayur000
Nice post.
But smart phones have smart battery management based on the environment, usage patterns, and background apps.
So it takes 30 days to calibrate battery.
If you want more from your device, then don't use the phone longer, take a break
OrcaDee
OK let me try
sahilgg
Bhai this issue is also there without updating.
Jerrydon
Im also facing the same issue starting from first 6.1 update. Samsung is not at all looking into our concern. 😂
goodthings
Your's device is new so please give it's some time. After some time and after some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
As per your concern, we have noted down the feedback. We are continuously working for making our products better and more efficient. We would request you kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open the Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select Error report > select the appropriate issue category> Type your query and send).
OrcaDee
None of them solved the issue, Samsung you are losing trust on your loyal customer base, please for the next update fix the battery draining issue for all s23 ultra users , We need justice
JithinAjith
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
