a month ago (Last edited a month ago ) in
Galaxy S- Mark as New
a month ago in
Galaxy SAdd apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
a month ago in
a month ago in
Galaxy SDear Samsung Member,
1. When you expose the Galaxy Buds to very cold or very hot temperatures, the useful charge may be reduced.
2. The battery is consumable, and the useful charge will get shorter over time.
3. When you are not using the earbuds, store them in a charging case that has been charged.
If not, the touch-sensitive sensor will continue to work, affecting the usage time and battery consumption.
Kindly reset the buds: Galaxy Wearable App>Tap on About earbuds.>Reset earbuds.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
a month ago in
