Resolved! Solved
S23 ultra battery drain
(Topic created on: 10-20-2024 04:02 PM)
cprboxin
My s23 ultra battery 🔋 drain faster after Oct month security patch update...
Will any one facing same issue?
2 Solutions
nj_sama
Yes I have brought the new phone and i see battery is draining faster 😫
goodthings
6 Comments
nj_sama
S23ultra_guy
Been on one ui 6.0 and still facing the same issue
YoVi23
You mean you didn't update ? Now this raises the question is it really a UI update thing ? Or is it like same pokemons having different stats ?
goodthings
S23ultra_guy
I went to the service Centre and gave them the logs which was generated while putting the phone to maintenance mode. They coudnt see anything unusual.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that as for npw, there is no such issue repoted. However, kindly perform the following steps to resolve your issue by the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
