S23 ultra Battery drain so fast !
(Topic created on: 09-26-2024 05:41 PM)
ʋɨֆɦռʊʋɨʋɛӄ
Did anyone facing the same ?
7 Comments
It's snapdragon version !
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
DRNavedIqbal
Yess got just 5 to 6 hours sot
DTnmy
Yup
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Navigator2023
Yes experiencing the same
