Resolved! Solved
S23 ultra 1x flash grain issues
(Topic created on: 02-01-2025 06:55 PM)
simar48
Regarding the attached image, captured using a single 12MP shot with flash enabled, I observed significant noise, or graininess. Is this a common nighttime photography issue experienced by all Samsung Galaxy S23 Ultra users?
goodthings
Please clear catche and clear data of this app also reset camera settings and reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too also clear catche of all apps manually then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
8 Comments
goodthings
simar48
Yes I ll try it and if works I do accept ur solution
goodthings
Your's most welcome to here.
The noise or graininess you've observed in your nighttime photo is not uncommon, especially when using flash. Here's why:
Factors Contributing to Noise
1. *Low Light*: Nighttime photography often involves low-light conditions, which can lead to noise.
2. *High ISO*: To compensate for low light, the camera may increase the ISO sensitivity, introducing noise.
3. *Flash*: While flash can help illuminate the scene, it can also create harsh shadows and accentuate noise.
Samsung Galaxy S23 Ultra Specifics
The S23 Ultra's 12MP primary sensor is excellent, but it's not immune to noise in challenging lighting conditions. However, Samsung's advanced image processing algorithms and noise reduction techniques help minimize noise.
Comparison to Other Devices
Noise in nighttime photography is not unique to the Samsung Galaxy S23 Ultra. Most smartphones, including those from other manufacturers, may exhibit similar noise characteristics in low-light conditions.
Tips to Reduce Noise
1. *Use Night Mode*: Enable Night mode to allow the camera to capture multiple frames and merge them, reducing noise.
2. *Adjust ISO*: If possible, adjust the ISO setting to a lower value (e.g., ISO 400) to reduce noise.
3. *Use a Tripod*: Stabilize the camera to avoid camera shake and blur.
4. *Avoid Over-Reliance on Flash*: Try to use natural light or alternative light sources to minimize flash-induced noise.
By understanding the factors contributing to noise and using the tips provided, you can improve your nighttime photography results with your Samsung Galaxy S23 Ultra.
simar48
I ve clicked a lot of night pictures Turing on flash on my iPhone I haven't issues like that before . To avoid this graininess I ve done a shot Turning on night mode and yeah there's no such issues
OK 👍
If I answered yours quiry then pls accept as a solution 🙏click on the 3 dots on reply section to accept 🙏Thanks
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
