Fix my issue
(Topic created on: 02-01-2025 06:02 PM)
Priyu_9
Please fix my camera issue
goodthings
6 Comments
TROVE
Nice Shot 👏
To post in the Galaxy Gallery section, please follow these steps:
1. Tap the three dots in the upper-right corner of this page.
2. Select Edit and choose 'Galaxy Gallery' as the section instead of 'Galaxy S'.
If you find this helpful, kindly mark it as a solution to assist others:
1. Tap the three dots on my reply.
2. Select "Accept Solution."
Thanks for your support!
goodthings
Please clear catche and clear data of this app also reset camera settings and reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too also clear catche of all apps manually then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
Priyu_9
I try it but not work 😕 any other solution
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
