S23 fingerprint recognition problem
(Topic created on: 02-25-2024 12:40 AM)
Nirmal_S23
In my S23 I have enabled fingerprint always on function but whenever I put my phone in pocket than also fingerprint sensor keep getting activated though Pocket mode is on. What can be a possible solution?
5 Comments
santoshbha1
Turn off the touch sensitivity from display settings it might help.
goodthings
Kindly reset all settings of your's device in general management settings also turn off the touch sensitivity in display settings, then try to it's again. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
vinayshah
Try disabling "Touch Sensitivity" from settings & see.
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips for better understanding. This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
