Resolved! Solved
S23 Ultra One UI7.0 - Battery Level sign missing - Resolved
(Topic created on: 06-05-2025 07:02 PM)
epixelate
Since the One UI 7.0 stable update for S23 Ultra, the battery level indicator in the status bar is missing.
Its visible right after a restart, till all the phone functionality is up and running.
Good Lock> QuickStar > Visibility indicators - Battery indicator automatically turned off.
_the_Devilman
Have you ever hidden your battery icon on one UI 6 by using good lock?
5 Comments
_the_Devilman
epixelate
Not that I remember, if 'ever' tried that?
I don't even remember under which of the many good lock apps, do many of these feature settings even come under.
epixelate
Thanks for suggestions, indicator settings were turned off
Mani4
did you hide it using good lock, if not, first clear cache partition, if doesn't work, then format thae device after backup.
please accept it as a solution if it works.
cs_member10
Dear Samsung Member,
As we have checked you have mentioned that your issue has already been resolved. If you have any further queries please feel free to get in touch with us.
