02-03-2024 08:54 PM in
02-03-2024 10:15 PM in
Galaxy S- Mark as New
02-04-2024 10:36 AM in
02-04-2024 03:46 PM in
02-05-2024 12:05 PM in
Galaxy SDear Samsung Member,
Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
Clear SoundAlive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search SoundAlive> Storage> Clear data.
Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
In case the issue still occurs kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
