S23 FE - Battery issue when hotspot is enabled
(Topic created on: 08-01-2025 05:07 AM)
impratheeban
In my S23 FE, when I turn on the hotspot tethering, the battery goes down like a bullet train. If I plug in the charger, even though it's showing super fast charging, in reality, it's charging like a tortoise. If I turn off the hotspot, then it charges fast. Also, network sharing is too slow, even though it's 5G.
Another pinpoint: if the battery goes down to 10%, within the next 3-5 minutes of normal usage (just the screen on), it goes to 0%. I mean, 10% is equal to 0% in usage.
Anyone noticed this issues?
2 Comments
goodthings
goodthings
You're welcome to here.
