S23+ Battery
(Topic created on: 03-20-2024 09:55 AM)
Msc786
My S23+ Battery seems to drain quicker then usual does anyone else have the same issue
8 Comments
Not applicable
If you don't mind could you send us a screenshot of the battery stats? They're under settings>battery, click on the area where it says "Today" and take a screenshot. Do it before going to bed so that more data will be shown
Msc786
Not applicable
Go down a bit, we need to see the apps' battery consumption
Msc786
Not applicable
The list looks fine. What's worrying is the total battery usage of 120%, definitely weird. Contact Samsung by opening the Members app, go to Support on the bottom right corner and scroll untill you see Error Report. Click on it and follow the steps
Msc786
I charged it full this morning at 7am
I then put it on charge when it was 19 % at around 5pm full charge
Msc786
Ev4ns
Beginner Level 3
Go to diagnostics and click battery and see what it says, maybe the battery has a problem
