Expected battery life of s23 ultra
(Topic created on: 03-29-2024 10:59 AM)
AddiP
I would like to find out from other S23 Ultra users what their average battery usage is per day and what your on screen time is?
If possible provide screenshots.
I am scared my phone is underperfoming and I might need to send it into samsung to get it fixed. On average I am getting arround 4 hours for 70-80% usage and very occasional like 90% usage for 2 hours of on screen time.
On youtube I keep seeing much better battery performance from the s23 ultra so that is why I was concertned.
6 Comments
outcast1
4 Hours **bleep** thats horrible😅such an expensive phone
TeeA
My problem is that I don't like the new way of how it reports the battery usage but what I can tell you is that my average daily SOT is usually between 7-8 hours and the battery lasts for 20-21 hours with my 'heavy usage' but when I keep it light it can go up to 2 days, probably even longer if I activate the power saving mode.
It also depends on the type of apps you're using and how long you use them. Also check that the adaptive battery setting is on as well. 1711742138616.jpg
Zvi88
Depends on your usage and signal strength. If you have poor reception the phone will drain faster just sitting on a table.
AddiP
What is the average on screen time you are getting?
Zvi88
I have a s22 ultra and get a full days use sometimes even 1 and a half days battery life.
They are a plethora of settling to extend battery life. Put sleep or deep sleep hardly used apps, reduce screen brightness when indoors, connect to wifi instead of mobile network, use Modes to create a power efficient profile. Turn off BT and Location when not in use.
Also be aware that the chips in these phones are very powerful and will drain faster especially if connected to 5G and making use of sensors or features.
AddiP
Can you please give details on what settings or modes you use to get this battery life?
