Battery consumption on s23 ultra
(Topic created on: 03-30-2024 01:14 AM)
Not applicable
I have been noticing that my device is consuming power even when idle how can i improve the battery life
10 Comments
Maerro
Put it on power saving mode
Not applicable
Will it not affect perfomance
Maerro
Yes it will, but when in idle you don't need that power..like when going to sleep
Not applicable
Ok but previously it did not consume power whilst idle
Not applicable
Hello, when replying to someone you should click on the reply button or else the person you're replying to won't know who you're talking to
shakira786
I notice the same. When im not using my device. The battery is a certain percentage and when I unlock the device it's less. This changed once I did the update. Something is running in the background
TeeA
I don't understand the question since the battery will sip battery even when idle. For example, I charged my battery to full at 23:12 yesterday when I woke up now at 06:55 it was 97%, which is normal for me every time since I noticed it would only stay at 100% for like an hour or two if I don't use the phone.
To answer your question, things like switching the performance profile to Light may help, as well as Power Saving mode and making sure the Adaptive Battery setting is on so that the battery adjusts to the way you use your phone.
Not applicable
I slept my phone was on 95% but woke up when it was below 85% could it be attributed to the fact that i have not been using the proper charging brick?
TeeA
It is possible, what type of charging brick are you using?
