Resolved! Solved
S23 Battery Drain Issue - One UI 6.1
(Topic created on: 04-19-2024 10:43 AM)
alfayeed
Beginner Level 4
After upgrading to One UI 6.1, the battery performace has degraded. Previously, I used to get almost 5 - 5.5 hours SOT (85% to 20%).
Now It hardly lasts 4.2 - 4.5 hours. (80% - 20%).
Please look into it Samsung.
Note: I use maximum battery protection and power saving mode.
In One UI 6 the battery protection limit was 85%. (This was better)
Now, In One UI 6.1 the battery protection limit is 80%.
2 Solutions
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
Ajay_das
Call to customer care 1800407267864 Complaint dere battery draining issue, say next update plz recover
13 Comments
goodthings
goodthings
Your's most welcome to here.
Bhava003
Issues after OneUI 6.1 Update.
- Animations are not smooth.
- Charging speed is slow.
- Battery drains quickly.
- Camera quality has degraded.
- Touchscreen issues.
- Fingerprint sensor lags.
- Face unlock sensor lags.
- Heating issues.
- 5G data Problem.
- AOD
- Not Added new Fonts.
- Add more widgets.
- Poor RAM Management.
- Add One Click to All Apps Catch Clear.
- Good lock Problems.
- Give more S-Pen future.
- Green line issues some users .
- Video Calling Effects not working properly.
alfayeed
Beginner Level 4
OneUI 6 was far better.
This AI integration killed the stability.
am100
U can make routine to stop it at 85%
alfayeed
Beginner Level 4
Great buddy. Thanks for the tip. I will create the routine.
Atleast one problem solved.
am100
Happy to help. If u can go through some trouble back up all ur data n factory reset ur phn n go to service center and ask them to re install latest os they have. It will solve battery drain.
V05
How do we do that?
am100
U know how to make routine?
