Resolved! Solved
S22 ultra 5G netwark issue
(Topic created on: 05-07-2025 08:03 PM)
gladiator027
During extended gaming, VPN use, or YouTube 4K Ultra HD viewing, the device overheats, and the network automatically switches from 5G to 4G LTE until it cools down. This has worsened, especially when using the phone outdoors where the ambient temperature is nearly 38–39°C daily as per indian climate; the phone is overheating excessively. Samsung please resolve this issue.
Resolved!
12 Comments
MohiVsnv
At this point this piece of metal should only be used to text or call😂😂
gladiator027
Haha true😂😂
cs_member8
Dear Samsung Member,
As per your concern, we want to inform you that while using 5g networks due to higher power consumption causes the mobile phone to heat, and if the phone is connected to multiple networks at the same time, the battery may drain faster, and the phone heats more than usual.
● If you are facing more heating as compared to normal, kindly perform the following steps
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
● Please follow the below steps to reset the device:
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
● If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
