S22 problem
(Topic created on: 03-17-2025 09:59 AM)
biddu_sr
Hi all,
In my s22, now i am facing system UI issues like System UI not responding or One UI home not responding. Sometime the phone even goes back to auto restart. This problem has occurred after thr lastest softwate update.
I have even tried to factory reset but it has reduced but not fixed.
Anyone facing the same problem or what could be the reason, hardware issue or software issue. Possible fix.
Regards
Rohit
7 Comments
Kaustav_Ray
Expert Level 3
I understand you're experiencing frustrating "System UI not responding" and "One UI Home not responding" issues on your Galaxy S22, along with occasional auto restarts after the latest software update. It's definitely concerning when these problems persist even after a factory reset.
Let's analyze the situation and explore potential causes and fixes:
Since the problem started after the latest software update and persists even after a factory reset, it strongly suggests a software-related issue, such as a bug or incompatibility introduced by the update.
Here's what I recommend:
Report the Issue to Samsung:
Use the Samsung Members app to report the issue directly to Samsung. This is the most important step. Go to the "Support" section and choose "Error reports".
Check Samsung Community Forums:
Search the Samsung Community forums for your device model (Galaxy S22) to see if other users are experiencing similar issues after the update. If others are reporting the same problem, it further suggests a widespread software bug.
Check for Software Updates (Again):
Go to Settings > Software update > Download and install.
Even if you've already updated to the latest version, check again to see if Samsung has released a hotfix or patch to address the issues reported by users.
Clear Cache Partition:
Clearing the cache partition can sometimes resolve issues with system features. To do this:
Turn off your phone completely.
Press and hold the Volume Up button and the Power button at the same time until the Samsung logo appears.
Use the Volume buttons to navigate to "Wipe cache partition" and press the Power button to select it.
Use the Volume buttons to navigate to "Yes" and press the Power button to confirm.
Once the cache partition is wiped, select "Reboot system now" and press the Power button to restart your phone.
Safe Mode:
To enter Safe Mode:
Press and hold the power button until the power menu appears.
Long-press the "Power off" option until you see the "Safe mode" prompt.
Tap "Safe mode" to restart your device in Safe Mode.
In Safe Mode, use your phone normally and see if the System UI or One UI Home issues occur. If they don't, a third-party app is likely the culprit. You'll need to uninstall apps one by one to find the problematic one.
Smart Switch (Reinstall Firmware):
Connect your phone to a computer and use the Smart Switch software.
Smart Switch has an option to reinstall the firmware on your phone. This can sometimes fix software issues that a regular factory reset doesn't resolve. Important: This will erase all data on your phone, so be sure to back up your important files first.
Given that the issue started after a software update and persists even after a factory reset, it's highly likely that it's a software-related problem that Samsung needs to address with a future update. Reporting the issue to Samsung Support and checking the community forums are the most important steps you can take.
Kaustav_Ray
Expert Level 3
If this helps, please accept it as a solution. Click the three dots on my reply and select 'Accept Solution.' Thanks!
Kunapatra
I think this is software issue so kindly contact with Samsung official care or visit nearby Samsung Care
janviji
You must go for nearby samsung store and flash your device once.... surely your bug will clear dont worry about that
MishraJiLive
No, It won't fix your issue. I also tried through service center they are suggesting to replace mbd
janviji
This is frustrated 🥴
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
