S22 Ultra Battery
(Topic created on: 06-21-2025 07:27 AM)
Piyush0188
Battery draining very fast after updating to UI 7.0 at full charge giving battery giving backup for around 6 hrs. And drain 2-3% every 3 hrs at standby mode.
6 Comments
BiRdMaN
This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will fix it in the next update
If you find this helpful please Accept it as a Solution Thank you 😊
goodthings
goodthings
Your's most welcome to here.
Piyush0188
Thanks, I have sent above mentioned log and error to Samsung Support. Awaiting for there review.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
