S22 Plus Line Problem
(Topic created on: 09-09-2024 01:18 PM)
Arcaneblackez
Line appeared on right side mysteriously
5 Comments
Biren55
Post this issue on Twitter, Facebook, and Instagram by tagging Samsung India so that you will be contacted later.
Also, email it to the Samsung India CEO.
Rasihan
When did this appeared?
After updating?
Arcaneblackez
Yes, happened post the August update
Rasihan
Thanks for the info!
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
