S21 Fe has battery issues
(Topic created on: 09-02-2023 12:22 PM)
samz2
Beginner Level 4
It's barely been 6 months since I've brought this phone and I'm experiencing battery drain on standby mode and also less usage time. I even got the mother board replaced and also the battery was checked and now the service centre executives claim it may be a software issue and a lot of S21 FE devices are experiencing the same issue. I've spent a lot of money and this is just infuriating. Samsung do something
17 Comments
samz2
Beginner Level 4
I've done everything before...no point....I think it's a software issue. They have to fix this
Rajendra4126
Facing Same problem
goodthings
My dear complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report. Thanks
goodthings
My dear turn on power saving mode, location turn off, when necessary open than close. Stop all background apps, stop adaptive brightness, stop vibration, remove unused apps, turn it on safe mode. Thanks.
aviash77
Switch off the mobile will get 100% battery
MohammadAquib
Big Battery 🔋 Drain Issue All S21fe
prasadroxx
Battery draining on standby mode is main issue
rajhassan31
No problem battery working fine
