08-29-2025 09:47 PM in
Galaxy S- Mark as New
08-29-2025 10:06 PM in
08-29-2025 10:22 PM (Last edited 08-29-2025 10:22 PM ) in
08-30-2025 09:10 AM in
Galaxy SDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
08-31-2025 01:29 PM in
