S21 FE network issue while using dual SIM.
(Topic created on: 03-07-2023 05:19 PM)
iM20
Hello guys, I am facing a weird issue with my S21 FE from the day 1. I have my Jio SIM in slot 1 and BSNL SIM in slot 2. I mainly use internet through Jio. But the issue is, if both the sims are activated and if Jio mobile data is turned on, the Jio connection stops working very often. After every few minutes interval, only the "up arrow" below the LTE sign is shown and the "down arrow" remains grayed out (screenshot added). Both the calling features (if anyone calls me during this time, it is said that my phone is switched off) and internet don't work for a few seconds and then again it starts working for a few minutes. It happens again and again. But if I deactivate the BSNL SIM, this issue doesn't occur.
Have any of you come across the issue? If yes, then please let me know how to solve this. Thank you.
15 Comments
iamrohitkm
This happens sometimes don't worry.
iM20
Not sometimes, this has been happening for me everyday and even every hour. Sometimes 2-3 times in an hour.
iamrohitkm
I am using airtel and jio in my s21 ultra I can also see the same thing happening but jio internet is working fine.
Arigh
I have only one sim jio and it happens, others say my phn busyor unreachable but thats not the case..my previous samsung A71 had also this issue with jio.Thought its a fault of jio network but many users use jio,they do not complain, so i think its jio and samsung compatibility issue. Airtel, Vi sim working fine. Iphone has also same issue with jio
iM20
Oh, so that's the case. Thank you for the info. :)
Arigh
Thinking of port out to vi but internet connection not good in vi,or have to try others non-samsung phones
Shubham332
Don't update your samsung mobile phone.
As you will keep updating the mobile and time will pass and one day you'll think that this phone is useless and it's time to buy a new phone.
Samsung is crippling our devices monthly.
neeve
Yes I'm facing the same issue actually I'm regretting on buying Samsung s21 fe. I am also facing the same network issue the 4g mobile data breaking at frequent intervals,its not an issue with a particular sim. I'm facing it in all sim card.Definitely its a problem with the phone..
cs-member11
Dear Samsung Member,
We apologize for the inconvenience you are facing. We understand your concern and will help you resolve this. Kindly follow the below steps to resolve your issue:
Check device network mode settings
Please follow the below steps.
Step1: Navigate to apps screen and tap on Settings.
Step2: Tap on Connections.
Step3: Tap on Mobile networks.
Step4: Tap on network mode SIM1 or SIM2.
Step5: Select network mode.
Note: We recommend to set device network mode as LTE/3G/2G or 5g (auto connect) mode.
Check network operator settings
Kindly set device network operator as "Automatically".
Step4: Tap on Network operators.
Step5: Select automatically.
Note: We recommend to set device network operators as LTE/3G/2G (auto connect) mode.
Step6: Tap on OK.
Step7: Registered on network.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
